I need a car (I’m less fussy than Emp so this thread won’t be 100 pages)
12346»
  • crunchmancrunchman Frets: 11465
    Emp_Fab said:
    I’m sure half of you will be thrilled to discover I have an unbelievably annoying rattle somewhere under the dashboard in my Civic.
    I’ve now ripped out half of the interior, and it’s still there!!
    Given your avatar, shouldn't you be looking for one of these?
  • TTonyTTony Frets: 27657
    Which model Civic do you have @Emp_Fab?
    I'm pretty sure that the rattle was a standard feature on some of them.  It was a special design feature intended to keep the drivers awake.
  • Emp_FabEmp_Fab Frets: 24422
    I've got the 2.2.  I've worked out that it's heat related - sort of.  If the car has been in the sun and the dash is warm, it rattles.  If it's cold - no rattle.  Once I find my USB endoscope, I'm going to look inside the air vent ducting in case there's a small coin or something lodged in there.
  • wibblewibble Frets: 1110
    inb4 have you checked the nut behind the wheel?
    I FOUND IT !!!!!!!!!!!!  It's a small bit of loose plastic trim on the top edge of the wing in the engine bay !!!   It was nothing to do with the dashboard at all !!
