And a good bass obviously. Sell the thin stringed tat if you need to.
#bassmasterrace
You only need a little, like say a square centimetre in each corner. Use big strips and yes you'll need a crow bar to shift stuff.
Literally.
Go to 7:28
1. Nope I can't.
2. Evidence and Cornish cables are far too pricey to be breaking.
Re the patchbay- no- more so take anything out that COULD fail or introduce failure or noise.
Tuner first and some double as a handy mute if you are changing guitars.
Didn't get along with the mojomojo at first (wanted something with more mids) but have come to quite like it as a smooth overdrive sound for rhythm, and boosting it with the soul food does great things. Now I just need a Phase 95 to go sideways on the back row....
https://www.pedalplayground.com/
Leave some room for an ABY box at either end,
Don't rely on velcro / dual lok, if you like where they sit, drill some holes and use tie wraps to secure them semi permanently.
It will make sense when you actually take it out the house.
