https://i.imgur.com/mGHksmP.jpg
Trading feedback here
Won't help with your typical pedal train though, as those are made of alloy I think .... my experimental board is a chopping board with the sheet metal on it. Once I've thought it through properly and prettied it up I'll post some pictures.
The magnets are actually really cheap as they come in boxes of 25, the screws are also very cheap but there's no standard with thread sizes amongst pedals, least not mine.
This does of course have the slight disadvantage that you can only replace it with another Boss pedal unless you want the whole thing to end up like a Swiss cheese, but since I pretty much only use Boss pedals...
Clean it with glass cleaner (its a banging degreaser) before hand then when fully dry stick it on without touching the adhesive or rubber.
