Project Debut Carbon, 2m blue, acrylic platter and more
Okay the vinyl is going full stop, absolutely gutted. I have a dealer coming to view the collection so I will have the turntable to go.
2m Blue with low hours
2m Red with low hours
Acrylic platter
Original metal platter
Project Phono box
Totalling £600 ish
£280 delivered (BT for payment please)
Great turntable, if you were splitting would be into the blue and the acrylic.
Good luck with the sale!
Will PM you.
I have messaged the seller but his outlook is that I’m going to have to suck it up. Tough!
I’m pissed off because upgrading the stylus is the main reason I bought the turntable. A replacement costs around £130.00.
Like an idiot, I didn’t insist on using PayPal. I won’t be making that mistake again. It’s a pity, it just puts me off buying from forums.
As I have pointed out to you, the message I sent to you, saying it sounded great was within about an hour of fitting the stylus to my turntable. It has deteriorated- because at some point prior to it being fitted the cantilever has been bent. There is no way I can set the tracking alignment correctly, which is why the sound is deteriorating.
Like Steve said - a bent cantilever will sound the same from minute one.
What alignment protractor did you use?
#2 - It's down to the buyer and seller to both do their research and due diligence.
#3 - If you guys (either or both of you) want to play this out in public, it will not end the way you're hoping.
So...how about you knock it off and take it to PM, as it should be?
