Guitar serial numbers in adverts
phil_bphil_b Frets: 2010
edited May 2021 in Guitar
When selling a guitar is it a good idea to disclose the serial number. I see a lot of adverts where the serial is blocked out. Is there a good resion to do this
  • rlwrlw Frets: 4732
    No.
  • thermionicthermionic Frets: 9671
    rlw said:
    No.
    Why?
  • phil_bphil_b Frets: 2010
    rlw said:
    No.
    No? It is not a good idea to share the number
    Or
    No there is no good reason not to?
    Ha, I misread the question as well! I can’t think of a logical reason not to. It could help reduce the scams where people steal photos from other listings. I have blurred them out in the past but don’t now.
  • WhitecatWhitecat Frets: 5452
    I think in the past people used to think that a SN was TMI and could be used to fraudulently lay claim to an item claiming it was stolen/lost or whatever... I think in a day when things are way more documented than ever that would be really hard to do though now.
    No reason not to show it.  If someone decides to try and sell your guitar based on your advert, as a scam, that has no effect on you.   And the serial number is a good way for people to check authenticity, providing the seller is straight and not a scammer.
    phil_b said:
    rlw said:
    No.
    Or
    Yes.  Sharing the number isn't an issue to me and no, I can't see a reason not to.
  • SassafrasSassafras Frets: 30310
    The police took a dim view of me blacking out my car's number plates.
  • prowlaprowla Frets: 4942
    I can't see a downside of showing the s/n, unless you stole it.
  • AlterlifesonAlterlifeson Frets: 477
    I read the title as guitar serial numbers in TV adverts! Like a quick shot of the back of a headstock of a guitar propped up against a sofa.
  • DrJazzTapDrJazzTap Frets: 2171
    Depends on the guitar I'd presume? For a limited edition thing then I would be tempted to block the number out.
  • GuyRGuyR Frets: 1357
    Blocking the serial numbe from an ad listing has always mystified me. I am genuinely interested to know what unwelcome consequence advertisers are concerned might result from displaying it?
  • Handsome_ChrisHandsome_Chris Frets: 4779
    Someone putting it on a counterfeit version of the advertised guitar?
    Counterfeiters don’t usually go to that much trouble. Most of the Chibsons seem to have a serial number that could have appeared on a Gibson, but I don’t think they ever match up to the correct model.
    edited May 2021
    I considered that, but wouldn't it be riskier for the counterfeiters to imitate a guitar currently advertised for sale than put on a random age appropriate number? There is nothing to gain by duplicating a number.
  • ICBMICBM Frets: 72627
    There is if they duplicate one which matches a correct model description - it means a check with the original manufacturer on the fake serial will indicate it’s genuine.
    It doesn’t even have to be counterfeiters either - just a simple scammer can make a note of it, *not* necessarily include it in the stolen pics, then give it to a prospective buyer if they ask for it to check the authenticity, which then seems to confirm it.
    If you can’t think of scenarios where knowing a genuine serial number can’t be of use to someone dishonest, you aren’t thinking hard enough.
  • FunkfingersFunkfingers Frets: 14573
    edited May 2021
    Wrong approach.
    A former work colleague of mine had new plates made when he bought a pre-owned car but "accidentally" left the protective film on them. This was highly reflective - to the point that the flash used with GATSO camera's would flare, rendering his index number unreadable.
    edited May 2021
    Fair points, I guess I am not suspicious enough by nature, although neither of the examples would disadvantage me if I were selling, for example, a vintage Fender and a professional counterfeiter would probably choose to avoid unnecessary risk by cloning a serial number not currently for sale.
