Amp volume gradually lowers when playing??
13»
  • NerineNerine Frets: 2180
    So. I should be getting my amp back today.
    Marshall called and said that they had the amp on soak for a while.
    So what was the problem?
    Output valves, apparently.
    They re-valved it, ran it up for a good while and all seems to be well. It’ll be interesting to see what happens when it’s back in my company. I shall give it some pain tomorrow to see what it’s like.
    I’m dubious that this is what the cause was, but we’ll see. I’ll leave it on for a few hours and see if I have any of the same problems. Fingers crossed I don’t.
    In any case, it’ll be cool to have it back. Thinking I may keep hold of it as I want to try it with an EQ in the loop and a potentially a Boss SD-1w in front for some proper hair rock.
  • Ahem.
    Ahem.
    Bye!
  • FuengiFuengi Frets: 2850
    Interesting thread, my Blackstar Studio 10 EL34 is doing this too.
    I'd put it down as a valve fault and was anticipating replacement of both, but this has prompted my to go back to PMT as I only bought it in October to ask for a replacement.
    I've told them I think it's a bad solder joint.
  • rossirossi Frets: 1705
    Its the electrons escaping from your lousy playing.Practice more and they will return like faithful puppys to your wires .
    I don’t even kn… errr….. what?
