Overdrives that also work into clean amps
  • monquixotemonquixote Frets: 18289
    Many drives are tweaked tubescreamers though and some of them sound rather better like the Fulldrive in MOSFET mode.
  • dindudedindude Frets: 8617
    Dave_Mc said:
    I haven't tried it, but as far as i'm aware a signa drive is basically a tweaked tubescreamer, so if you don't like how a tubescreamer sounds into a clean amp...
    That's far too simplistic I'm afraid, yes it is TS derived, but what isn't, even though I draw the line at inflated prices an marketing BS, I don't get the "all tube screamer type pedals sound the same" argument, I've tried enough and they really don't.
  • nickb_boynickb_boy Frets: 1689
    Out of my current dirt collection I'd say the JHS Double Barrel fits in to this category. I tend to run it mainly with my EmDrive already on, set to a very low setting (never really turn this thing off) but it also works in an untouched clean channel. The Morning Glory side gives an early break up sound to a clean amp with some nice colouration then the ts808 side sets it over the edge. I'm going to be interested to see how this compares to the Rook Royale I have on the way!
  • Dave_McDave_Mc Frets: 2452
    Yeah of course, I'm not saying that you can't change how the thing sounds by changing a strategic component here and there, just getting something which is completely different may sound even better into a clean amp. or may not.
  • p90foolp90fool Frets: 32367
    I don't know why the general consensus is that tubescreamers don't work with clean amps. Granted, you may need a proper hairy-chested amp like a four-input Marshall, but it works very well for me.
    Small boxes with a single 12" and too many 12ax7s always seem too mid-heavy for a TS no matter how expensive, but big, deep-voiced amps which were in common use when the Tubescreamer was designed still sound great with it.
    I'm normally using blackface type amps where it makes you sound a bit like you're playing down a telephone line.
  • ICBMICBM Frets: 74281
    I still find them too middy and boxy, and I do use big deep-voiced amps. (Actually very deep-voiced amps... the sort of sound I always wanted out of 4-input Marshalls but could never get deep or heavy enough.) I actually much prefer 'distortion' pedals into clean amps, they sound much more open and chunky.
    It's horse for courses I guess, I wouldn't advocate the use of a TS into a clean amp as a core sound, but it certainly has its uses for me in the studio, controlling some of the inherent boominess of some old halfstacks.
    A lot of that clean, natural depth can get lost in a mix.
  • Since realising that they had a loop into which I could put a delay I'm quite enamoured of the Mk1 Guv'nor
    What's the difference with that and just putting the delay after the Guv'nor?
  • EricTheWearyEricTheWeary Frets: 16634
    you can do OD+delay with just one stomp of your Doc Marten.
  • stickyfiddlestickyfiddle Frets: 28628
    VALVESPORKER!!
    VALVESPORKER!!
    I would if I could find one, but a certain otter stopped making them.
  • thomasw88thomasw88 Frets: 2370
    I always liked a TS into clean amps,  turn the tone down to about 10 o'clock and keep the gain around 10-2 o'clock. Worked for me anyways.
    other pedals, are the Barber Small fry which is awesome.  I'm liking the plimsoul at the moment, initially when I got it i  didn't take to it, but after a bit of fiddling starting to dig it big style.  seems to work nicely into clean amp and also a dirty channel.
    Things I'm interested to try include the AC Boost and the Signadrive.
    For what it's worth, I've A/B'ed the AC Boost and LSIII - not sure which I prefer, they're different but not wildly so. The AC is maybe slightly smoother on the drive (TS heritage, I suppose) and more 'hi-fi' sounding, especially on the top end - with a big clean fender you might be running the AC with the treble at the centre notch, or even slightly below.
    I've not monstered the AC through a Twin, but have found it to work well with a DRRI both above and below amp breakup levels. I'd definitely give one a go, given the second hand prices and availability.
  • The vs route 66 is a great drive for pushing an amp, then flip the bass boost on and it makes for a nice drive for smooth, but crunchy, chord playing. It even gets rawky on a bridge bucker if you want it to. I really like it. Switch the compressor on at the same time, and things can get pretty cool.
    And I just so happen to be selling one :D
  • WazmeisterWazmeister Frets: 10082
    edited September 2013
    Best ever ? Kingsley Jester...
    Most consistent ? ANY of the Bearfoot range
  • OilCityPickupsOilCityPickups Frets: 11741
    I think one of the most under rated pedals out there is the Digitech Bad Monkey. I've used one as the core of my overdrive/distortion sound for the last five years or so. I either run it as a clean boost in front of the drive channel with some beans already applied ... here it sounds great ... or I use it with about three quarter drive on the clean channel ... and it sounds brilliant used like that too. It  now sits in my pedal board with a Joyo 'American' amp side of it ... and a Tubescreamer guitar side of it. Run with my clean channel the Joyo is set to just break up when I hit hard ... then the Monkey does heavy crunch ... and I can step on the Tubescreamer for a smooth solo boost. Amazingly this rig is very quiet
    Was looking at the Bearfoot website the other day, very confusing range I have to say, but I am a Bjorn Juhl fan so there must be some good stuff in there somewhere.
  • mike_lmike_l Frets: 5700
    I agree with the BM being under rated. I loves mine, although I use it as a gain/volume lead boost rather than a "core tone" pedal.
    I find it sounds best into a valve amp (DSL) but a bit dull/lacklustre into a SS (Valvestate 30)amp.
