Actually the red stripe ones aren't quite as bombproof as the older models.
That sounds like obvious transit damage, in which case the first thing I would do is contact the seller and see if he'll refund even before assessing it for repair. If it's been thrown out of the back of a lorry it could have something fairly major wrong with it, there isn't a huge amount that could easily come loose without causing substantial damage.
It's not too difficult to open up and have a look, and completely safe if it's not plugged in. Just undo the speaker connections and unscrew the chassis.
I don't know any repairers in that part of the world unfortunately, but there's bound to be someone who does.
While since I have needed to use him (hopefully he's still going), but he is long established & was very good (based at 5 Woodville Court, SR4 8RF, just off Chester Road/A183).
The website I last had details of isn't working, but here's a Facefook account that might help?
https://www.facebook.com/cameronelectronics.co.uk
These are easy amps to take apart, and if you use the right screwdriver so you don’t chew the bolt heads, it won’t leave any evidence.
As a goodwill gesture i have offered to go halfs with the seller.
