Tele bridge - uncomfortable
PoboyPoboy Frets: 431
edited July 2021 in Guitar
Damping with the edge of my right hand is a big part of my playing and am finding it really uncomfortable on the tele. Can even get painful.
As far as I can tell it's the edge of the little grub screws for height adjustment on the saddle that's the culprit.
I dont want to fit one of those ashtray cover things as I think they look crap and I wouldn't be able dampen properly any more anyway. Which would kinda defeat the purpose of it.
Is there any other solution? I've tried searching for more subtle covers, maybe something like little rubber caps for the screws, but can't find anything.
It's putting me off playing the tele.
  • andy1839andy1839 Frets: 2197
    I get this on Strat and Tele type bridges as I set mine really low.
    I usually buy a set of spare grub screws and just grind them down so they sit either flush or just under the hole.
  • PoboyPoboy Frets: 431
    Hi Andy, might work. Seems a lot of effort though.
    How do you grind them down? They're tiny....
  • p90foolp90fool Frets: 31618
    You can buy the screws in different lengths, put shorter ones in.
    0reaction image LOL 0reaction image Wow! 8reaction image Wisdom
  • TheBigDipperTheBigDipper Frets: 4796
    I bought new Graphtech saddles (and graded screws of different heights that matched the neck radius) for my MIM Tele Deluxe FSR. - which has a 6 saddle Strat-style bridge, not the classic Tele one.
  • keirkeir Frets: 137
    edited July 2021
    I got a set of intonated Glendale saddles for my tele and they have recessed screws. They have increased sustain a bit on the originals but are fairly expensive,
    Good deals with: handsomerick, majorscale, gassage, sticker, smudge_lad, anglian, edinfield99, thewiddler, thomfripp, notonlybutalso, JDE, chebellanga
  • stickyfiddlestickyfiddle Frets: 27113
    Yeah, either shorter screws, or shim the neck to increase the angle and get the saddles a little higher on the current screws.
    It's usually the simplest solution is the best.
    Where would a handsome young fella, such as myself, purchase aforementioned shorter screws?
    I'll look into that too. Money is no object.
    Not sure if serious....
    It is an option, I've used the microtilt on my Strat to enable me to raise the saddles on their screws.
    https://www.ebay.co.uk/itm/6-Guitar-Saddle-Height-Adjusting-Grub-Screws-in-Chrome-Various-sizes-/371950037510?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
    Just order whatever sizes suit, I did buy a staggered set for my Silver Sky but still needed to take a little bit off each with a bench grinder (probably not the best solution to be fair)
    Thank you!
    Six short ones ordered....
    Absolutely serious if it means sorting in an hour with a bit of cardboard rather than waiting on delivery of new saddles!!
  • WezVWezV Frets: 16725
    yeah, you can put a shim in the neck pocket like this Fender example here - then raise all the saddles
    shims can be any thin material.   Card, plastic, wood veneer... they all work fine
    No hurry. I've short grub screws on order, I can wait for those. Thanks anyway.
  • elstoofelstoof Frets: 2498
    Don’t forget to raise the pickups if you ever shim a neck
  • RickLucasRickLucas Frets: 405
    They sand down really easily.
  • Philly_QPhilly_Q Frets: 22957
    Thank you!
    Just a note on those, they're metric thread so may not fit if you have a USA Tele...!
    They've just arrived... I thought I was ordering six screws. I had actually managed to order six sets of six...  =)
    If anyone wants a set, hit me up.
  • ICBMICBM Frets: 72420
    Entirely serious. I would do that too, as the simplest solution - it also increases the break angle over the saddles, which some people prefer.
    Now you have so many spare screws, I'm sure someone else will want them though!
