All of my gear lives in a large cupboard, safely away from the wrecking ball that is my son. Even with everything you need for a wired setup within easy reach, it still takes a few minutes to get going, and then there's always the possibility that you end up down a rabbit hole with your pedals etc and don't actually practice. With the Boss headphones you can be plugged in and playing within 30 seconds - which means you will, and often. That's what you're paying for.
Just so I don't sound like a shill/fanboy:
- the gyro feature does not work, and it wouldn't be my cup of tea even if it did
- it would be better if the ambience could be dialled lower than the current minimum level
- I wish it was USB-C rather than micro-USB, and that the battery life was a bit longer.
Perhaps these are the kind of things that might be ironed out in any future v2 release, but I wouldn't hesitate to buy them regardless. Some of the best money I've ever spent.
If I had had the Wazas when I was first starting to play I’d be a much better player today.
I would recommend it to anyone
Just to reinforce the point... I happened to bring them to my parents' house yesterday for my dad to have a go - he's been playing for the best part of 60 years and I don't mind admitting he's a more talented player than me. He also rarely gets the opportunity to plug in and, unprompted, basically said exactly the same thing about the difference it made to his touch when playing. I've asked him if he fancied a pair before, but my mum needs round-the-clock care and he worries about his attention wavering while using them. I'd argue he could do with the respite (as would she), so might keep planting the seed now I know he likes them...
(the gyro feature doesn't work, forget about it).
the headphones can simultaneously handle the guitar input (via MIDI, no detectable lag), a connection to the Tone Studio app for editing and a Bluetooth connection for a backing track, from a separate device to the app if needed.
all cable free, plug in and go. makes my so called "bedroom amps", which in my experience sound rubbish at true shared-house bedroom level, redundant.
if you only practice somewhere you can crank your amp, you don't need it.
The app appears to have a metronome and some grooves for jamming - no idea if that's a new bass specific app or it's an upgrade to the generic Waza Air app.
the MXR 5 knob compressors are identical and yet the money is very different.
