Auden Chester £675 - no longer available
19791979 Frets: 87
edited October 2021 in Acoustics £
I bought this to try alongside a dreadnought to compare and have decided to keep the dreadnought.
This is a good quality 000 that is in excellent condition bar the two marks pictured on the top and a bit of buckle rash on the rear.
The frets have a few marks but I can’t feel them when playing it. It has the original hard case with it that is pretty much unmarked.
Here are the specs from the Auden website. I have contacted Auden and will amend if necessary, should it turn out these aren’t exactly right.
Top: AAA Spruce
Back: Rosewood
Sides: Rosewood
Neck: African Mahogany
Joint: Dovetail / Hide Glue
Fingerboard: Ebony
Head Plate: Ebony
Nut: Bone
Detailing: Maple / Mahogany
Bridge: Ebony
Saddle: Bone / Composite
Pins: Ebony
Machine heads: Schertler 18:1 open
Finish: Full Gloss
Preamp: Brad Clark Supernatural
Case: Vintage Grey Buck
Dimensions
Shoulder width: 285mm
Belly width: 395mm
Waist: 235mm
Depth at neck: 90mm
Depth at Base: 115mm
Full length: 1060mm
Scale Length: 655mm
Neck width at Nut: 43mm
Neck width at 14th: 54mm
Neck width at 20th: 57mm
Postage will be by overland express or a meet-up could be arranged . Any questions or extra photos, just ask.
https://imgur.com/gallery/4j1hVrX
https://imgur.com/gallery/CsrahIt
  • That is a nice looking parlour.
  • RolandRoland Frets: 8731
    If I want to see pictures then I guess others will, so:
    I do like the grain on the sides:
  • DeadmanDeadman Frets: 3914
    edited September 2021
    Wow. Pretty much my perfect acoustic.
  • 19791979 Frets: 87
    Thank you, again, ;
    If it goes, I won’t delete the price this time!
    PM’d @Deadman ;
  • pjfpjf Frets: 331
    Looks great! Not mahogany (/sapele - “African mahogany”) in that above photo though. Appears to be rosewood of some description.
    I’m sure it’s some form of rosewood. My Taylor has the same striping, and that’s billed as rosewood.
     @pjf I think you may be right. I have emailed the guys at Auden and will report back with what they say, thank you.
    Just waiting on an update from Auden regarding the wood identification….
    I have had confirmation from the nice people at Auden regarding the construction.
    This is what it’s made of -
    R - Rosewood
    S - Spruce
    T - Triple 0 (000)
    F - Full Body
    I will amend the ad if that helps anyone. I am also going to get it set up and the frets dressed next week should that tempt you
  • StrangefanStrangefan Frets: 5844
    Very tempted but no ones tempted with my gretsch! So I can't make an offer :/ It's a funny old world.
    You never know what’s going to happen @Strangefan ;
    fingers crossed
  • TeyeplayerTeyeplayer Frets: 3229
    Having recorded with a very early version of this model and played a few more Auden models since, these really are fantastic acoustics, can’t recommend them highly enough. Best of luck with the sale, someone will be getting themselves a cracking acoustic.
    Thanks @Teyeplayer it is the most expensive acoustic I have owned and the dynamic in sound is quite something. It gives you back exactly what you put in
  • AmigoAmigo Frets: 120
    It seems that the Auden parlours and 000s are a bit thicker in body than a standard parlour 000, aren't they?
    Yes that seems to be the case @Amigo ;
    the body depth tapers from 90mm to 115mm
    PM'd
