and of course anyone else who fancies a crack @thegummy or @robinbowes maybe?
R.
Eqd Speaker Cranker clone
Sorry if that's a daft question, but I normally skim over this section and thought I'd finally ask the question.
there plenty of scope there with those tracks!… 70+ To play with.
is anyone having issues with the files lining up properly? @Siejen is reporting a slight issue that I’m not getting.
Can you clarify the issue, and I can check.
do yours? When you hit playback is it all over the shop or does it sound like the track albeit unmixed?
I think I might know what happened.
I notice, in Reaper, all tracks have a tempo imprinted @120, which is wrong apparently.
Also, when I imported each group of tracks, I got a pop up asking if I wanted to import tempo information- per track, which seemed to be related to the track's number, ie, track number 64 was set to tempo 64---that's not accurate, just a description of the message that pops up.
I imported each group separately, into a group folder, so I saw this message pop up a lot.
In all instances, I chose to ignore any tempo information, and currently have my project set to 120 bpm, there is no midi, so no need for a tempo map, but obviously if there are tempo markers or cues imprinted on the audio it could cause problems.
You said the track tempo was 75 bpm ish, but I know that some of the string parts ( all?) had tempo information matching the track numbers.
Sometimes Logic makes things completely Illogical, which is why it scares me, haven't bothered with the update as it seems completely geared towards a genre of 'music' that has no appeal to me.
Reaper FTW.
I'm joking, in case there are any people who have had humourectomies out there.
