I’ve propagated CAB and Reverb changes through a couple of other presets.
Often I add a bit of Chorus. This makes it sound less like an acoustic guitar, and more like the acoustic guitar tracks in many songs.
Ebay mark7777_1
Quite shocked at how straightforward it all was!
I’ve reached a simplification stage. Once I’d got my kitchen sink preset working I started investigating other Amp types. I’ve now got six versions of the kitchen sink. For performance I want that reduced. I can play most of our set with one preset which has five scenes, plus the ability to turn some key effects on and off: Chorus, Flange, Drive, Delay, and Mid Boost.
I'd say 80% of the set is one preset now, which is the culmination of years of tweaking and covers most bases I ever usually need. It's great to be at a point where I plug in, make a few minor output EQ adjustments for the venue and then just play.
For me the III is still the best piece of guitar gear I've ever bought and a total GAS killer. I'm on the waitlist for the FM9 but that's purely to streamline my gear to everything on one board
it was a big step up to the mk3:
For yesterday’s rehearsal I used the same preset for all but two songs. On the AxeFX II I was using five presets to give the range of sounds I need. With the III the Amps are more flexible, and I can get more sounds by changing pickups and tone.
As in that it's not passed on to you, the customer?
do G66 know how to handle the customs declarations for that, to avoid double Vat and duty?
