drum machine with bass drum only
BenSirAmosBenSirAmos Frets: 411
Having tried a few allegedly 'simple' drum machines, I now realise that all I need for live performances is a bass drum (or stomp box) playing four to a bar or in 12/8 time, that I can set the tempo with and switch on and off with a footswitch. I don't need snare, hi-hat or fills.
Can anyone tell me what is the simplest way to do this.
The 'simple' machines I've tried all want to provide pre-set full drum parts and the programmable machines seem very complicated to use live when I only want a bass drum beat.
What can I use? I don't even know what I'm looking for.
  • WhistlerWhistler Frets: 322
    You mentioned that this is for live performance and you mentioned stomp box. The Ortega Horse Kick Pro is among the best of its kind. If you have more space you could use a cajon with a kick pedal attachment, although you will get a cajon sound not a bass drum sound so it does depend on what sound you want.
    Thanks. For one or two numbers, this would be ideal but not for a whole set. I've tried a looper but I perform standing up so it is too tricky to set the looper while stomping. I think I really need a drum machine so it is one press for starting and another for the ending.
  • blobbblobb Frets: 2953
    Strummable drums has pads for bass & snare. I can't remember if you can set it so only the bass/snare trigger at the given tempo (3/4 or 4/4) but if it did, that would be what you are looking for?
    Feelin' Reelin' & Squeelin'
  • mrkbmrkb Frets: 6821
    edited November 2021
    Do you mean Digitech SDRUM? Yes you can turn off the hi hat pattern and only have a kick pattern, but it throws the odd snare hit in as a fill even on the simplest pattern setting. And only 3/4 and 4/4 patterns.
    Karma......
    Ebay mark7777_1
  • Thanks guys. I'll look into that and see if it can do what I need
    I can’t seem to get my sdrum to do kick only, would be useful if it could.
    Turn the Hats/Ride knob to select the position between the 1 and 12 pattern leds (ie no leds are lit)
    Karma......
    Ebay mark7777_1
  • This is sounding promising. I'm just looking through the manual - but I might have to buy it to try it out properly.
  • erky32erky32 Frets: 49
    I'm interested to read your plight... I've just posted a similar request in "Live" section. I use a Roland SPD-ONE KICK - it works really well, and sounds as good as any, but I wish I could find the same with an auto take over looper - get the beat goiing then let the electronics carry on. Doesnt seem to exist!
  • BenSirAmosBenSirAmos Frets: 411
    I've not found anything that does what I need it to yet. I've resorted to using a real live conga player. I'll keep an eye on your thread and if I do find anything, I'll let you know.
  • CryptidCryptid Frets: 406
    Is this a Roland device?
    It would be less trouble if it was
  • ICBMICBM Frets: 72361
    This will probably not be a lot of help unless you need the rest of it as well, but the Boss ME-50B bass multi-fx has a kick drum effect with foot tempo setting. It’s quite large compared to a single stomp box though. (But smaller than a conga player.)
    That's massively more than I need - but it does seem to do exactly what I want - so I shall investigate further.
    I mean, I can fit a conga player in the boot of the car, but the congas take up the whole back seat.
  • SR16 can do everything you want, simple to use and tap tempo, so you can do it all standing up without touching machines just two unlatched pedals.
    I had one of these when I was in a band and I sold it because I didn't need it.
    I might explore getting another but I didn't really like the sound that much - but it is a cheaper option.
  • prowlaprowla Frets: 4925
    Why not just plug in the bass drum?
  • JezWyndJezWynd Frets: 6062
    GarageBand or DM1. Requires a laptop or iPad but easy to operate once set up.
    No, no. Simpler, simpler. There must be something simpler - and smaller, I don't want to be setting up a laptop. I'd like something plug and play with one decent sound and a knob that makes it faster or slower.
  • Shark_EyesShark_Eyes Frets: 377
    You could look into the volca kick (probably a bit overkill) or the volca beats.
    Both have memory so you can save patterns, have start stop buttons and tempo knobs.
    Patterns are easy to make too, you can either press play and record at the same time and tap it in live. Or press record and just tap where you want the beat.
    You can set the number of active steps so you can set your time signature that way.
    There's millions of videos on these so you should be able to figure out if it's for you.
