Withdrawn Kawai MP 11 SE digital piano for synth
Having recently had an op on my wrist with another to follow tomorrow, I bought the above electric piano because I thought I wouldn’t be able play again.
So, I have a brand new Kawai digital piano at a cost of £1950 that I want to trade for something of similar or above value, I have cash available, anyone interested?
https://i.imgur.com/Tn35mvX.jpgSpecifications
Dimensions
- Width: 1380mm
- Depth: 452mm
- Height: 190mm
- Weight: 34KG
Keyboard
- Number of Keys: 88
- Key Material: Wood
- Key Tops: Ivory Touch
- Action: Grand Feel with Let Off Simulation
Sounds
- Sound Source: Harmonic Imaging XL
- Piano Sampling: 88-Key
- Number of Voices: 40
- Maximum Polyphony: 256
Effects
- Reverb: Room, Lounge, Small Hall, Concert Hall, Live Hall, Cathedral
- Number of Effects: 129
- Parameters Per Effect: Up to 10
- Amplifier Types: S. Case, M. Stack, J. Combo, F. Bass, L. Cabi
- Parameters: Drive, Level, Amp EQ Lo, Amp EQ Mid, Amp EQ Hi, Mid Frequency, Mic Type, Mic Position, Ambience
- Equaliser: 4-Band
Virtual Technician
- Touch Curve Settings: Light+, Light, Normal, Heavy, Heavy+, Off
- Touch Curve User Slots: 5
- Piano Parameters: 11
- E.Piano Parameters: 2
- Temperament: 7 Types
- Tuning: 3 Types
Functions
- Metronome: 10 Signatures, 100 Drum Patterns
- Recorder Songs: 10
- Recording Storage: 90,000 Note Capacity
- File Playing: MP3/WAV
- File Saving: MP3/WAV
- Internal Memory Sound: 40 Memories
- Setup: 8 Memories x 26 Banks
- Keyboard Modes: Full Keyboard, Upper Split, Lower Split, Zone
- USB Load/Save: One Sound, One Setup, SMF, All Sound, All Setup, All Backup
Connectivity
- Input: 1/4'’ Line In
- Outputs: 1/4'’ Line Out, XLR Out, Headphones
- MIDI: MIDI In, MIDI Out, MIDI Thru
- USB: USB to Host, USB to Device
- Foot Control: Damper, Sostenuto, Soft
- Power: AC In
General
- LCD Display: 128 x 64 Pixels
- Panel Controls: Volume, Line In, PIANO Volume, E.PIANO Volume, SUB Volume, Control Knobs A to D, Pitch Bend, Modulation
- Power Consumption: 20W
- System Menu: 52 Parameters
- Colour: Black
- Included Accessories: GFP-3 Triple Pedal Unit, Music Rest, Power Cable, Owner’s Manual
Its just a little heavy (my RD2000 is 22kg and just manageable) without roadies... Its got stunning sounds and the best keyboard available (part of the weight...full length keys).
Of I wasnt gigging Id grab this.... have nowhere to store my RD just for gigging purposes.
However, it is insanely heavy - my RD700SX is 25kgs (steel chassis vs alu on the 2000) and I recently decided to replace it after having to lug it up two flights of stairs for a gig (during which the grab handle tore off my heavy-weight case). 35kgs (plus case) would not work with my increasingly middle-aged back...
Top-notch choice for a static studio or stage though (or if, as you say, you have roadies or a very accommodating bandmate).
(I'm only posting this because it's been withdrawn!)
