Any use for US IEC leads?
Seems a complete waste to me that manufacturers ship things with 2 leads sometimes, a UK one and Euro or US lead.
I've a pointless collection of the things with no good use for them other than the bin which is completely wasteful.
What do you do with them?
I hate wastage, I think companies should include the correct lead for the country the product is selling in.
Anyway, any use for them other than landfill? Perhaps we should save them all and post batches to countries that can actually use them.
  • Put a UK mains plug on them?
    Cut the plugs off both ends and use them as speaker leads?
    <space for hire>
  • menamestommenamestom Frets: 4705
    Yeah, could be an option for home use, not a bad idea. Not sure you could use them at a venue.
    I used to dispose of them, right up until the point I actually needed one.
    Now I just keep a couple spare, they come in handy, along with a step transformer.
  • mrkbmrkb Frets: 6880
    I cut off the end and put a Uk plug on them.
    Karma......
    Ebay mark7777_1
  • Danny1969Danny1969 Frets: 10419
    There's no issue with an un-moulded plug from a PAT point of view as long as it's fitted properly
  • KittyfriskKittyfrisk Frets: 18827
    ^ This. Arguably a properly fitted plug can be better, as you can see that the connections are solid & good. You can't check this with a moulded plug.
  • robinbowesrobinbowes Frets: 3045
    The only problem with this is economic - UK mains plugs cost way more than a pre-formed IEC lead with a UK plug attached, especially the decent non-brittle ones.
    R.
    @robinbowes ;
    CPC part no PL10201 is £1.07 so not too bad if you are buying something else as well for combined shipping
  • ICBMICBM Frets: 72419
    That has a proper cable clamp too, unlike the ones with a sideways nylon ratchet thing which never holds the cable firmly enough.
    Failing to do the cable clamp up properly and so allowing stress on the electrical connections which eventually work loose is probably the number one fault with DIY-wired mains plugs.
