What amp am I looking for?
Ok so I just sold my last amp and now I need something to make noise with. I am after a 1x12 combo amp anywhere from 15 Watts and up. It needs to have an effects loop, it doesn't need more than one channel as long as that channel can get a little crunchy and has a master volume. Price wise I am looking under a grand, obviously the less the better. Any suggestions?
  • Lots of options! Any specific reason for the FX loop? Just a preference?
  • bertiebertie Frets: 13569
    edited January 2022
    also what kind of loop (series/parallel)  and does it need to be switchable
  • Looking as t the classifieds, the Friedman Runt 50 or the Mesa Lonestar Special would be top of my list.
    I like running a gritty tone but I want my time based effects in the loop. Series is fine with me I have a mix control on my obne mixer pedal.
  • What do we think about a Mesa DC3? I know nothing about Mesa amps and even less about older ones
  • ICBMICBM Frets: 72442
    Pretty good amp but rather dated now - it sounds very dark, aggressive and '90s'. You won't get anything like a vintage-style light-power-amp-overdrive sound out of it, nor a shimmery clean tone. But if you do like dark and gritty it might be ideal.
    The FX loop is dreadful too - it's a crude parallel loop that won't go to 100% wet and so causes trouble with FX units which digitise the dry signal path. I had the DC-5 and the only solution was to modify it to a series loop. (Not a big job, actually.)
    Well nuts to that then, cheers
  • Rowby1Rowby1 Frets: 1280
    Egnater Tweaker 15
  • monquixotemonquixote Frets: 17640
    I'm a stuck record but the DSL40 does a lot.
  • menamestommenamestom Frets: 4720
    Hot Rod Deluxe could be worth a look?
    Relatively light and loud and sounds good.
  • Hot Rod Deluxe could be worth a look?
    I used to have an hrd and while it was good value for the spec I found the touchy volume knob sweep to be unusable
  • I'm a stuck record but the DSL40 does a lot.
    I had never really considered Marshall but I hear good things about that one, will it do light breakup?
    The clean channel and crunch will both handle lighter gain.
    That's on the shortlist then. I am off to try a stoneham today hopefully but if that falls through that's my next stop
    that's what the old volume box in the loop "fixed"  ;)
    Yep that's exactly what I did. I would rather just buy an amp that worked the way I want without having to fix it though
    edited January 2022
    Easily fixed for £20 with a Dr Watson Lion Tamer .
    The newer versions aren’t as bad anyway, Fender changed the taper of the pot after endless complaints!
    I’ve never found them a problem really, but then I don’t use one at home volumes.
  • EricTheWearyEricTheWeary Frets: 16297
    Laney Lionheart?
    Effectively it's a crunchy 20w combo with a clean channel thrown in.
    People didn't like the parallel effects loop on the original UK version, I'm not sure what it's like on the later Chinese version or the new UK version. The spring reverb in the original was sacrificed for a slightly crappy digital one on the later versions. But it is an amp designed to live in that clean-crunch zone.
  • Laney Lionheart?
    I have always wanted the Lionheart 20 but never had a chance to try it out. It seems to fit the bill and I like an inbuilt tiltback, I hadn't heard about the loop issue mind. I tried a Peavey classic 20 a few years ago too and that seemed to be the right style but it was just ok, didn't blow me away
    Do you want me to do a quick phone vid of the gain sweep?
    What type of guitar do you use and what kind of thing do you play?
