The big black ones or the small silver MK2 ones?
Remove two of the screws from the bottom of the pedal, drill through the board in the right places, and fit longer screws that go right through the board into the pedal. From memory, they're M3 thread.
Drill two holes in the board either side of the pedal and run a large cable tie right around it, between the knobs and the 'step'.
Remove the rubber and use velcro. Also from memory, the battery door comes away with the rubber, so you probably need to not care about using it with a battery again unless you can re-glue it.
https://www.thefretboard.co.uk/discussion/189181/fs-marshall-pb6-power-supply#latest
I should have said, I'm ideally after a velcro solution because I tinker with pedal order etc a lot.
I've tried @ICBM 's cable tie technique, but on the Echohead for example, the presets are printed right under where the cable tie runs across, so unless you've memorised them, it's guess work!
I think I'm going to try the @ftumch gaffa solution - basically because it doesn't do anything permanent to the pedal, lets me use velcro and doesn't require me to buy anything I don't already have in the house!
Brilliant guys, much appreciated!
