How to post pics, Imgur
  • johnswissjohnswiss Frets: 393
    Test
    Test
  • Test
  • DeadmanDeadman Frets: 3902
    edited February 2022
  • MellishMellish Frets: 945
    @Deadman ; seems like that Auden is having a bit of a warm in the first pic ;)
    Haha. It was just the glow light. Nobody is allowed heat in my house unless it’s -5  ;)
  • NPPNPP Frets: 236
  • NPPNPP Frets: 236
    NPP said:
    bollocks.
    https://imgur.com/0M58w8x ;
    I am following the instructions: get correct link from Imgur, hit the folded over bit of paper icon, past and hit space, and nothing happens. What am I doing wrong?
    [img]https://i.imgur.com/0M58w8x.jpg[/img] ;
    ok I figured it out - I need the BBC code but have to delete the img bits, there is no correct link (or none I can find) that works 'out of the box' so I'll have to edit the link in Text Edit before using it here. Not exactly straightforward ...
  • TTonyTTony Frets: 27477
    @NPP ; - which bit of the guide here, isn't working for you?
    Or are you using a device that's not listed in that guide?
  • NPPNPP Frets: 236
    TTony said:
    @NPP ;; - which bit of the guide here, isn't working for you?
    hi @TTony I'm using Safari on a Macbook Air running Big Sur. As I said in the post above I can't get any of the links offered by Imgur to display an image. I do get a result when I copy the link labelled BBC code which starts and ends with (img) and manually remove the (img) at the beginning and end before posting it into the image link box.
    I also run a German keyboard in case that matters.
    Many thanks for your support!
    Maybe I should try a different browser and computer as well but it seems I've found a workaround.
    @NPP ;; - just fired up my MacBook/Safari and Imgur errors on me - can't even get to my images to test out what's going on.  I'm guessing that might be a privacy setting thing because it's working fine on Windows and iOS.
    One thing that does trip people up sometimes is this part of the process;
    • Top right of the homescreen is a little (round) button with your initials/avatar.
    • Click that button, and from the drop down, select Images.
    Access your images by doing the above,  *not* from your Imgur account homepage.  Select the image you want to embed, then Copy the link in the Direct Code box and paste here via the page-with-turned-over-corner dialog box
    And that should be that.
  • NPPNPP Frets: 236
    @TTony this is where I may be going off track then, right from the beginning. I don't have an Imgur account, I just upload the picture and get the link. Given that I've just started a project (that's the pic I uploaded) I'd like to document on here I should probably set up an Imgur account now.
    :D
    That would probably help @NPP !!
  • What code does the site actually use? If I want to post say 5 images at once without clicking and pasting each direct link separately, what do I use? BBCode? HTML? etc
    Easiest option for that @vaticancameos ; is probably to drag and drop the images directly into your post, and host them here.
    I think any of the usual hosting sites require you to at least specify the address/reference for each image separately, so a separate direct link for each.
  • vaticancameosvaticancameos Frets: 186
    edited April 2022
    Easiest option for that @vaticancameos ;; is probably to drag and drop the images directly into your post, and host them here.
    Ah, will the forum convert just straight-up http direct image links? Lets find out -
    https://i.postimg.cc/xCkQbzjq/IMG-1028.jpg
    Drag and drop doesnt seem to work
  • equalsqlequalsql Frets: 6108
    edited May 2022
    Testing fretboard file upload
  • <blockquote class="imgur-embed-pub" lang="en" data-id="a/X745p6D" data-context="false" ><a href="//imgur.com/a/X745p6D"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
  • Nope, still can’t get IMGUR to work
  • FiftyshadesofjayFiftyshadesofjay Frets: 1428
    edited June 2022
    <a href="https://imgur.com/hBOYf1e"><img src="https://i.imgur.com/hBOYf1e.jpg" title="source: imgur.com" /></a>
  • There you go, never get fined again when visiting Guitar Guitar and PMT
