3PU LP Custom Build
DannyPDannyP Frets: 1682
edited February 2022 in Making & Modding
I'm planning a 3 pickup LP. I'd like to have push/pull pots turning the 3 pickups on and off, with the conventional LP toggle acting as a phase switch for the middle pickup.
Does this look about right? TIA x
https://imgur.com/wGK3i1w
https://i.imgur.com/wGK3i1w.jpg
«134
  • ICBMICBM Frets: 72644
    It will work, but you'll get a loud hum when all three pickups are turned off because the output will then be open circuit. Luckily, there's an easy way to avoid this - use the other three poles of the pull-switches connected in series from the common hot to ground, so that the output is muted when all three switches are off.
    If you can't visualise how to wire it - as it appears in the diagram -
    On the neck pickup switch, connect the two middle terminals together. (Where the red wire goes to the other middle terminal.)
    Also on the neck switch, connect the lower right terminal to the middle right terminal on the middle pickup switch.
    On the middle switch, connect the lower right terminal to the middle right terminal on the bridge switch.
    On the bridge switch, connect the lower right terminal to ground.
    You'll also need to use shielded cable for the pickups, and a 2-core+shield for the middle pickup wiring, both to the phase switch and from there to the pickup (you probably know that!).
  • DannyPDannyP Frets: 1682
    Thanks so much for taking the time to check that over!
    Is this what you meant?
    Yes, exactly.
    You can actually wire those three switches in any order which is convenient physically, as long as they're in series - that was just the easiest way of explaining it on the drawing :).
    Fab, thanks so much!
    In the world of wood, there's some strange wavy open grain in whatever it is Chinese kit makers are passing off for mahogany nowadays.
    Before I grain fill tomorrow, I've given it a quick pass with 800grit. It now feels better but looks worse.
    No matter, it will get a solid finish because it's an LP Custom and I'm not a lunatic.
    2reaction image LOL 2reaction image Wow! 0reaction image Wisdom
    I'm working on decal designs too. Undecided.
  • abw1989abw1989 Frets: 641
    Left hand side feather logo would be my choice. It's different enough, but still similar enough at a glance to the Custom diamond.
    There’s someone here who had a dark cherry one that looks amazing.
    Thanks, I think I agree.
    With this project, I'm quite influenced by 70s Japanese customs - Burny etc.
    Yes, that's fair enough. I can imagine it looks great.
    I'm not into the ones you see in Guitar Kit groups on Facebook. It seems that, given free rein, most people want trans green or purple-burst!  :o
    I'm personally a fan of tobacco burst on a Custom, here is my '84 Burny:
    They are gateway drug mind you... I've since acquired an arctic white Gibson Custom too.
    Alright, alright, but APART from the dark cherry ones and the tobacco-burst ones.......
    what have the Romans ever done for us?
    Tailpiece holes? Where we're going, we don't need tailpiece holes...
    OK, plugged, filled, sanded and glued.
    I went all George's Marvellous Medicine in the kitchen, assembling astringent yellow stuff to age the binding. I ended up with lemon juice, cider vinegar and turmeric.
  • WezVWezV Frets: 16788
    that might end up day glow yellow.  I would just spray tinted clear.
    The old ones are still nearly white under the lacquer, you can see it at the high wear areas and fretboard face
    Ah sure it'll be grand once I've give it a rub! I quite like yellowy binding like you get on ESPs.
    I left some weak ferric chloride on the cheapo shiny Bigsby overnight. I need to wipe off the residue.
    ah, mustard yellow then.  Even they seem to be white binding with colour sprayed on.  They again have pure white plastic showing on the fretboard face.. It stands out a lot more than on an old LP
    Maybe I should have added a dollop of Colemans to the mix!
  • elstoofelstoof Frets: 2521
    French’s Yellow surely
    I agree.  much more likely to stain things :D
