It has a slim neck by 5-string standards so you'd probably find it a bit easier to adjust to coming from guitar. Not as cheap as a Harley Benton, but you're unlikely to find a better bass for less money.
Reverse pickup installations where the BEA string part of the pickup is further back work far better, but something with a bridge pickup as well is better again.
The Ibanez Mezzo 5 string (32 scale) works very well (is a PJ) and if you are looking for deep dub sounds then a set of Dunlop flatwounds would be a perfect match. That's what I've got on my Mezzo 5.
In my opinion, Fender/Squier P Bass guitars stray out of their comfort zone when a low B string is added. (Even retuning a four string to BEAD.)
My solution is to go active.
