Was bored again so I did sumfink else…
  • poopotpoopot Frets: 9099
    prowla said:
    poopot said:
    Based on the drive I did a few weeks back but with a stacked boost infront which can be used on its own… needs a name now… will sort the out side when I’m next bored…
    A Trapeze?
    Eh?
    edited April 2022
    More underway :)
  • andy_kandy_k Frets: 826
    Can I order one?
    andy_k said:
    Can I order one?
    Doing the next two for the brum show… lemmie get these done first :)
    Yes I know the serial says 0002… I picked up the wrong box :)
    Here you go… all three done… and all three will be at the brum show.
  • LastMantraLastMantra Frets: 3825
    Does painting the inside of the box improve the tone?  :)
    Yes…
    and also stops stuff grounding out if someone pushes part of the circuit when they’re not sposed to!!!!
    but mostly the tone!…
  • FunkfingersFunkfingers Frets: 14718
    IMO, given the circumstances, it might be appropriate to close this thread.
  • DeadmanDeadman Frets: 3953
    I get where you’re coming from, of course, but I dunno about that. And I’m just a bit sad that I didn’t tell him that this was a beautiful piece of work before he died. Just look at it. It’ll drop down the ranks eventually, sadly.
