Someone will have one in a drawer somewhere.
I need to check whether a G4M key and shaft fits a Squier backplate and gear wheel.
UPDATE:
The Squier and G4M 'heads appear to be different in every critical respect.
Same gear ratio, different wheel sizes. Different baseplate outlines with the mounting screw holes spaced ever so slightly differently. The key plates look the same but the flanges on the shafts that locate them in the baseplates are spaced differently.
i.e. Somebody who has installed a Hipshot Xtender/D-Tuner device.
Alternatively, invest in a Hipshot BT7 detuner yourself. Use the original E 'head to replace your damaged one.
The back of the tuners are stamped with what looks like fjn but cannot find any reference online, any one know the manufacturer?
Sent Fender an email requesting a part number but still waiting for a reply.
https://ibb.co/LJTLL4f
Squier VM ones do not.
I referred to Squier CV basses because that is what I have in front of me for comparison and/or reference purposes.
