Wilkinson Trem in drop tuning
So after seeing Steve Vai I wanted to give Bad Horsie a try.
Took my Wilkinson Trem equipped shred machine tuned it to drop C and found I can't pull up at all.
So loosened the spring claw got the bridge floating nicely, pulled up a semi tone (about all I can do on this guitar) and the springs fell out.
What's the solution?
  • ICBMICBM Frets: 72459
    Fewer springs with the claw tightened.
    Might be difficult if you only have two in at the moment...
  • WezVWezV Frets: 16733
    balance less spring tension with more string tension  -  heavier/different strings
  • FunkfingersFunkfingers Frets: 14482
    drop C
    Wot Wez sez.
