I've had several amps from this era over the years, and having recently purchased a Princeton Reverb II from the gentleman and monster-picker that is
@jamesoliver1234 as well as the Super Champ I bought a month or so ago I thought it was time for a thread.
I've previously owned another Super Champ and PRII, as well as a Champ II and a DRII.
Unsurprisingly, they're very different. The bigger PRII cab and speaker does make the Super Champ sound a little boxy when played side by side, but the Super Champ has such a lovely thump in the lower mids so it still sounds bigger than it's size suggests. There's a reason they record so nicely.
What was more surprising was the difference when using a reactive load box and the same IR for both amps. The Super Champ still had it's lower mid thing going on and plenty of treble. The PRII had more upper mids, even with the mid control set to zero. It also had less treble and more bass. Ignoring the horrible lead channel, the Super Champ transition into overdrive is slightly smoother and more pleasing to my ears - the PRII is a bit more aggressive and snarly. Both decent tones, but I think the Super Champ shades it. It may be valves, I've not actually looked to see what's in the PRII, the Super Champ has the original supplied USA-made tubes.
This PRII has a Pyle-made Fender speaker. My last one had the optional
EV with the metal dust cap which I thought sounded pretty crap unless it
was brutally loud (and the amp had run out of headroom). But then I've
never really got the hype with EV's, they just sound bland to me...
Side by side, the PRII sounds better - but through the loadbox and IR, I think the Super Champ has the edge.
What's annoying is I wanted to keep the best sounding one but I might actually have to keep them both!
Champ II
PRII (with EV)
DRII
I really quite fancy a super champ II but have no real need for one!
They look good together though.
The date codes on the transformers suggest 1984. It looks like you've got the reverb pan on the base of the cab. Mine is on the side. They sound much better on the base, I'll move mine at some point.
since 84, I’ve had 3 X Concerts,(All Sold).
I still have, and use frequently,..
I X Princeton Rev II,(Currently fitted with a Celestion Gold, but for many years It had Celestion Sidewinder fitted).
Modded as follows,(Mid boost switchable, using the reverb button on the footswitch).
Mid boost frequency is selectable,(3 frequency Options) , via a 3 way toggle switch on the underside of the chassis.
The mid pot has been replaced with a 25K, offering a wider range.
2 X Super Champs., Modded as follows,..
Mid boost switchable using the Reverb button on footswitch.
1 X had an EV 10 from new, but currently has a Celestion Gold 10”.
1 X has been converted to a head + 1 X 12 Cab, in polished Mahogany, by Mongotone, & fitted with an Eminence Cannabis Rex.
(Same Mid boost mod, as above).
2 X Twin II Combo’s, fitted with Celestion Sidewinders, & modded as per the Princeton II.
(I did install EV12L’s in one but it was virtually impossible to lift).
The best amps Fender ever made, in my opinion, hence my commitment to fine tuning them to perfection..
From memory, it weight slightly less the space shuttle at lift off weight...
I also had a "Concert" - is that a thing... I think that is what it was called.
Yes, the Concert was a thing - it was a 60 watter and came in 1x12, 2x10 and 4x10 as well as a head / cab option. I like these too, although I don't really need anything that loud.
Got mine a few months back and I still feel I'm only scratching the surface of what it can do. It's a beast.
I have one of these, although not this one.
Paul Rivera:
Source: Wheeler, Tom. The Soul of Tone: Celebrating sixty years of Fender amps. Milwaukee: Hal Leonard, 2007, pp 339-40.
I think Rivera left in 86, so probably not.
A 1984 Concert with a Eminence Patriot RW&B speaker in it. Serial F331652
The other is a near mint PRII that came with paper work, user manual, cover and original spares but no footswitch. However I found an original footswitch to complete the set later on. I'll have to add the serial later as I can't remember it at the moment and I'm away from home. But I think it's from 1984 too.
I sort of have a hankering for a Super Champ but what I have is already more than enough. Plus I don't have to worry about replacing that hard to find rectifier valve that the Super Champs have.
[This space for rent]
