The Bad Monkey is great too, but not quite a Tube Screamer.
TS808 sound, plus whatever else you want to add in or twiddle with.
Very affordable, much underrated & hilariously raucous or subtle depending on what you like.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Get something identical for under £20 delivered, or look elsewhere to spend a lot more.
if a TS is your chosen route then I recommend one with some control over bottom end - one mans mid push can be another mans thin sound
consider Way Huge green rhino or the Overrated Special or look at Horizon Devices Precision Drive - I know there are plenty of others with tone stacks but these are three I have and have worked as mid boosts and overdrive across a variety of amps,
good luck with search - its a well loved circuit with a load of variants and price points.
I've had the Keeley TS-808 Mod Plus (non true-bypass) on my board for over 10 years and I can hear the difference between that and a regular TS. It has a better response across the the controls, improved bass and is smoother and stacks well with other pedals, but you'd expect that, as well being great as a standalone pedal. I don't think Keeley make them anymore but the mod is well-documented. Used prices are strong (I paid around £150 new) but it's a good pedal. That said, I did try the Ibanez TS Mini and whilst I could hear a slight difference, it wasn't enough to warrant the difference in price between that and my Keeley and I think that's a good shout.
As has been said, the JHS Bonsai might be a good buy what's the point if you end up using one of the options and it's pricey.
The Nobels ODR-1BC ( bass cut) also comes recommended as does the Wampler Belle (ODR-derived).
They're ( way huge) 2 that I have been looking at actually...believe they're virtually the same pedal in the GR mk 4 configuration?
