Great basses.
The obvious choice is the EMG-35 series pickups, offering P, J and humbucker models plus a dual-mode model that switches between J and HB.
Seymour Duncan makes the passive NYC Soapbar - effectively, a double Jazz pickup - and the active Blackouts For Bass.
Bartolini, Delano, Nordstrand and others also make pickups in this size. I can not remember whether Aguilar offers any.
Thus, you could have a Mustang Bass and, then, choose how it will sound.
If I was buying a Mustang I'd go for a JMJ.
On a slight OCD level it does annoy me that they can’t set the switches at the right height too! (Although easily fixed - the threads should be flush with the top of the nut.)
Seymour Duncan pickup. It comes with flat wound strings which I really like. May be worth you checking one out.
It's only about an inch movement but it makes a surprising difference to the tone and really helps with a flubby P.
I've had it a couple of years now and it has GHS Precision Flats on it as I am a fan of thump. No hint of mud on mine, it has the Maple fretboard. I do find the tone control backs of nicely and still has sufficient clarity in all positions.
