Fender Short Scale Bass
  • chris45chris45 Frets: 221
    chris45 said:
    If it doesn't have to be a Fender, then Sandberg make an excellent Shortscale - the Lionel.
    The Lionel VS4 is a P bass type and the Lionel VT4 is a PJ type. They are available in gloss and matt finishes. Might need to be an order to get exactly what you want though.
    I have one in the build queue. Delivery next March / April. Can't wait!
    @fretmeister did you order direct or can you tell me which dealer you used?
    @chris45
    I ordered through Classic and Cool guitars on recommendation from the Basschat massive.
    https://classicandcoolguitars.co.uk/sandberg-new-basses/
    We went through the exact specs I wanted including ones that are not available on the configurator, and I've paid a £250 deposit. Balance to be paid when it's built and ready to be delivered.
    Thanks for the info :)
  • I'm a big fan of Sandbergs. I currently own 2, and I've had 3 others in the past.
    Great basses.
  • dindudedindude Frets: 8540
    Don’t be entirely put off by the Mustang PJ, see for yourself if it works, I have a lot of time for mine, plays nice, and sounds great. The P pickup on its own is a bit woolly but the 2 together is a fine base tone and the J on its own gets a bit of honk going.
  • Consider the Squier Mikey Way signature Mustang Bass. This came with a generic passive soapbar pickup and controls, making it easily upgradable using a professional quality aftermarket pickup.
    The obvious choice is the EMG-35 series pickups, offering P, J and humbucker models plus a dual-mode model that switches between J and HB.
    Seymour Duncan makes the passive NYC Soapbar - effectively, a double Jazz pickup - and the active Blackouts For Bass.
    Bartolini, Delano, Nordstrand and others also make pickups in this size. I can not remember whether Aguilar offers any.
    Thus, you could have a Mustang Bass and, then, choose how it will sound.
    Good luck finding one :(
    If I was buying a Mustang I'd go for a JMJ.
  • WhitecatWhitecat Frets: 5452
    Great basses.
    +1 - probably the best value in western-made basses at the moment by quite a ways. I have a J-style that was quite frankly a bargain considering the spec. Absolutely worth checking out.
  • ICBMICBM Frets: 72675
    edited September 2022
    It does look nice in that colour . It’s a shame the ones I’ve tried just haven’t sounded good - possibly a pickup change might help.
    On a slight OCD level it does annoy me that they can’t set the switches at the right height too! (Although easily fixed - the threads should be flush with the top of the nut.)
    It's worse on a Jazz - the smallest knob is always miles off the deck - I slap a star washer on the pot-side of the panel for each pot - as you say minimal thread showing above the nuts is the way to go
  • By an amazing coincidence, a pre-owned MIM Mustang Bass has appeared at a guitar shop near me. (No affiliation.) The PJ pickups have been changed to Seymour Duncan Quarter Pound models. The bass is Sonic Blue - no competition stripe. The shop is asking £450. This may include a gigbag. Definitely no case. Shipping a possibility.
  • TDubsTDubs Frets: 712
    Thanks @Funkfingers Which shop is this?
  • @TDubs PM sent.
  • PALPAL Frets: 542
    louis_LLM said:
    I’ve got the JMJ Bass in black, I use it regularly for country stuff and in my heavy shoegaze band, it seems to do everything, the pick-up is great, I just swap between flats and rounds and it has massive sonic difference. Had J and P basses before it and ditched them all, really can’t say enough good things about it!
    In answer to your question, best bet is probably looking at recent FSR stuff, possibly getting an import model, most of the historic mustang basses in nitro finish have the split coil pickup a la the JMJ bass.
    I also have the Fender JMJ Mustang bass and it's great it does have a wider nut width as it is based on  60s bass it also has
    Seymour Duncan pickup. It comes with flat wound strings which I really like. May be worth you checking one out.
  • fretmeisterfretmeister Frets: 24662
    If you can cope with a bit of routing and a new 'plate... swap the P pickup to reverse configuration so the bass side is closer to the bridge.
    It's only about an inch movement but it makes a surprising difference to the tone and really helps with a flubby P.
    That doesn't surprise me at all - I've just accidentally bought an old 80s Washburn Force 4, which is basically a slightly reshaped P with a reverse pickup (common among Japanese makers at the time), and I do feel it improves the sound.  It looks fine on the Washburn because you're not 'expecting' it to be the other way round.
  • prowlaprowla Frets: 4962
    I quite like having my MIM Mustang, though I hardly play it.
  • mbembe Frets: 1840
    I got a Bronco bass from Thomann that did have superb clarity but the neck was warped like a banana. I sent it back and ordered a Mustang PJ from GAK.
    I've had it a couple of years now and it has GHS Precision Flats on it as I am a fan of thump. No hint of mud on mine, it has the Maple fretboard. I do find the tone control backs of nicely and still has sufficient clarity in all positions.
    Off the bass I would have thought ‘what is that pickguard about’ but it actually works when on the bass!
    I bought it with that on and I like it.
    It was done by GIG.INK (https://www.originalscratchplates.com/).
