Plays well with AUM (that's worth looking into too) and my fishman triple play and best bit – it's free.
Yes. By far, even a recent iPad Mini (
> If I did that would any version of iPad do or do I need, say, a more recent type or particular spec?
Synths need CPU, and the cleverer the synth, the more CPU (i.e. ROMplers like Platinum Synth don't need so much). I use an iPad Mini 6 and that's fine
> Can I also hook up a proper keyboard to the iPad to make it a better playing experience?
Yes - a few do MIDI over WIFI (Korg Air, CME Xkey Air). But I'm suspicious of latency with those.
> If so, any recommendations for a particular model?
Fullsize or minikeys? If you want to add beats, then one with 8-16 pads is a good idea. Can use most USB controllers with an Apple CCK. I use an Arturia Keylab 61
I'd suggest an audio interface. But not all are iOS-compatible, so check for 'class compliance'
>I have a hifi system with Bluetooth, would that work?
Yes, except for lousy latency. Use wires. And be wary of using a resonant filter patch in the synth, it'll challenge what made-for-hifi speakers can manage.
> Or do I need powered monitors or an amp, and how do I hook either of those up?
To the same audio interface.
