New Neck?
UnclePsychosisUnclePsychosis Frets: 12961
I have a Vintera P, but I'm wondering if I'd get on better with a slimmer neck, so thinking about putting a jazz neck on it. The one on my Vintera Jazz is pretty much perfect.
Can I "just" buy another neck and swap them over? M a total ignoramus on that front. Are P and J neck pockets the same size?
Assuming the answer is yes - anyone got one going spare? Ideally off a "proper" fender with maple fretboard...as above - needs to fit on a Vintera Precision with no woodwork etc required.
@GSPBASSES perhaps?
  • OssyrocksOssyrocks Frets: 1673
    It’s my understanding that yes, they’re interchangeable. I sold my AVRI P bass for the same reason, I just couldn’t get used to the 44 mm nut width. All three of my current P basses have 41-42mm width necks now. I have a mate who has two P basses with Jazz necks too.
  • FunkfingersFunkfingers Frets: 14578
    By slimmer, do you mean shallower or narrower? Fifties P necks are wide and deep. Mid-Sixties P necks are wide and shallower than you might imagine.
    There are some perverse bassists who actually prefer a P neck on a J body. Perhaps, you can find one with whom to swap?
    If you are trying to maintain the Vintera pretence, the only Jazz Bass necks with maple fingerboards will be Seventies style examples.
  • UnclePsychosisUnclePsychosis Frets: 12961
    Narrower.
    I actually quite like a chunky neck, but the 44mm width on the vintera P feels huge.
    I could live with it, but where's the fun in that?
  • ICBMICBM Frets: 72668
    A friend recently bought a replacement Mexican Fender Tele neck from Thomann - it was quite cheap, although the nut was fitted so badly I had to replace it before it was usable... clearly a reject from the production line that they sold off as a spare part. Now it’s sorted it’s perfect though.
  • stickyfiddlestickyfiddle Frets: 27248
    44mm is daft. My P is 43-ish and that's enough of a handful. The non-vintage-style Fenders are all about 41 these days aren't they? No harm in picking one of those up
    edited May 2023
    Fender actually sell a maple vintera jazz neck as a replacement part, so in one sense I'm tempted just to buy one.
    But I'm also assuming I'd need to pay someone (you busy these days @ICBM ? :-D) to do the nut for me and the price is very quickly rocketing up...
    To be accurate, it was worse even than I described above - the *original* nut had clearly been ripped out with a pair of pliers or something, taking a bit of the finish (where it had flowed slightly up the side of the nut) and a tiny bit of the wood with it, then a ill-fitting cheap crap nut which didn't even look like the correct Fender part had been bunged in. Quite unbelievable, in fact... I was able to fix it with a new nut and some superglue to build the finish back up, but really not acceptable for a 'new' part from Fender. I think he did get some money back from Thomann.
    This is as it came from Fender via Thomann in an unopened box -
