Speaker/Monitor recommendations for a studio
  • mrkbmrkb Frets: 6937
    Where are you positioning the PA speakers? I cant see them in any of the photos.
    Karma......
    Ebay mark7777_1
  • KebabkidKebabkid Frets: 3339
    On the floor, one in front of the ceiling to floor bass traps and another across the other side of the room in front of another bass trap.
    Bass is reduced from the desk and the same from the EQ on the speaker
    Have you tried them on chairs/pa stands to get them away from the floor to avoid bass coupling?
    Karma......
    Ebay mark7777_1
    The stands have wide feet and so no room to use the existing ones and the speakers would need to be only a couple of feet off the ground as the lowness of the ceiling would mean they'd be blasting us at head or near head height if raised any more. I'll meause but the ceiling is just over 6 feet
    edited August 2023
    If they were “blasting you” at head height, then you can turn the volume down. PAs are designed to sound good at ear level. I have mini stands to get mine to about 4ft off the ground.
    NJS 35 mm Short Adjustable Aluminium Black PA Speaker Stand - Amazon UK https://www.amazon.co.uk/NJS-Short-Adjustable-Aluminium-Speaker/dp/B00GOQWI40
    Karma......
    Ebay mark7777_1
