Don't get a 1x12" with a V30 - even a Mesa one. The V30 always sounds least good in a small 1x12". Get one of the cabs with a Black Shadow 90 instead - it's a much bigger-sounding speaker which works better in 1x12"s and will offset the low power of the amp to some extent.
If you can get a cab with a Classic Lead 80, it will be close(ish) to a Black Shadow - it's not the same, but much closer than a V30. Not knowing your exact taste I could be wrong, but I would definitely avoid the V30 - I love them with Rectifier-type amps in 2x12"s or larger, but every Mesa 1x12" I've heard with a V30 has sounded excessively middy, shouty and directional.
Same here, but it seems to need more space. In 1x12"s - especially small ones, especially open-back and front-loaded most of all, it gets very shouty and beamy as well. It's also one of the few speakers that really does need to be given bit of power to start to open up a bit - amps with a lot of bottom-end will do it, but otherwise it can sound a bit stiff at low volume.
If it means saving up for another month to drop more money on the deposit and reduce the monthly cost a bit, I say it's worth it. You take your playing seriously and you won't regret it
At the moment you know you definitely want Mesa. But you could try one of these 25-watt Mark V's and hate it. Make sure you compare it to something with a bit more wattage behind it, so you know what you're missing. I used to gig with a Dual Terror, and was quite content... but then I started to miss the balls of a huge amp, and when I compared it with a bigger amp the Dual Terror just had to be sold. Even at the same volumes, the bigger amp had more balls. I forget which amp it was... I think it was the modded JCM900 I had borrowed from a friend for a while.
I understand the desire for a Mesa, but don't narrow down a huge decision based on brand. Go play stuff.
