It also sounds so good that he’s not using the LA30BL now. Genuinely good, not just ‘it will do because it’s so light’. It also has a ton of useful other features and is a huge bargain for the price - under £200 new - in my opinion.
How do you find the noise level on your Caliber 22?
Bandcamp
I've also got an EHX 5mm, which is fine for home use despite a slight hair-trigger volume control. It's just a power amp.
The Laney is a whole bloody loud two-channel amp with boost in a pedal format.
Whats your take on the durability, etc? I seem to remember you're not a fan of those Class D mini lunchbox amps that all the bass players love...
It is quite ironic that he's got this when I've just bought a Fender Bassman 50 valve amp
