Boss OD-200 opinions?
  • spev11spev11 Frets: 333
    I've found a workaround after a bit of googling, if you turn the dial of the parameter you want to check one click and then switch to the next memory setting and back again it flashes the saved value on the screen, its a bit fiddly but it works, i'll be writing everything down as i set it up as I really like the drives and the boosts
