Really looking for a multi fx that is small enough to pop in my gigbag, but also capable of amp/cab simulation so I can plug direct to the pa.
My aim is to have a ridiculously simple load in/out capability when using IEM
I also think I'd find the lack of a screen problematic. Still looks like a great bit of kit though
https://drive.google.com/file/d/1Cq8dk60mWy5gJ_1YveeRtM4-701y0pd7/view?usp=drive_link
I have the Line 6 Pod Go which is a very good all-in-one mfx solution, and utilizes Helix modelling. Not as powerful as Helix LT but its compact, light, with good floor control and expression pedal. Since v2.0 it has the new cab engine and IR cabs from Helix v3.5.
I know you have some experience with the Zoom G5…to your knowledge is there anything out there with the same functionality / workflow but with better sounds?
I just use 1 patch, in stomp mode, sometimes all 9 fx, which I can see what they are by their graphics (with some deft scrolling), plus tube booster. I could sacrifice the z-pedal. I need to be able to have multiple instances of the same fx.
thanks!
I've had both the G5 and the G5n. Do you need just FX or amp/cab modelling too? The G5n was better sounding than the G5 but the amp models took up 2 blocks, and cab model 1 block whereas all of that was one block in the G5. And some fx eg EQ took up two blocks too, so you could use up its 9 blocks pretty quickly!
I'm not personally familiar with the Boss GT1, but as @ICBM points out it's a pig to tweak on the fly.
Multiple instances of the same FX can be a problem if the FX you choose are heavy on DSP eg spring reverbs in Helix.
However, the Boss GX100 could be your best option. No fixed blocks, AIRD amp modelling brought over from the flagship GT1000, 150 Boss fx, dual routing and (subject to DSP limits) can allow up to 15 blocks so you should have plenty of scope for multiple fx versions in the same patch, Boss build quality, all metal construction, decent options to program control switches with good floor control, touch screen, built in expression pedal, good edit software, can hold up to 20 third-party IR's, and prices have dropped a bit. Great quality sounds, typically c£449 (GAK, Gear4Music), IntaAudio are currently selling these new with free delivery for £432. That's a cracking deal, & I think you'd be hard pushed to find anything better at this price point!
https://www.inta-audio.com/boss-gx-100-next-gen-guitar-effects-processor-p17306/s17313
There's also one on EBay 'opened-never used) for a BIN of £385 plus £15.45 or best offer
https://www.ebay.co.uk/itm/256367363581?
but frankly, unless he comes down a fair bit you're safer/better to buy it new!
I do think Zoom are missing a trick…they had such a perfect system with the G5 (and G3 etc) but they ruined it in the G5n and that horrible G6 monstrosity.
But if it had been out when I bought Pod Go I'd have snapped it up.
Line 6 Helix LT into DSM Simplifier mk2 into FOH.
My rationale is that I'm never happy with the amp modelling in the Helix, so I'll use Helix as an FX processor only, 4 cable method, time-based/modulations in FX loop of the DSM, comps, drives, wah etc in front of the DSM.
Thoughts?
Feedback thread: https://www.thefretboard.co.uk/discussion/comment/3575378
(Fan of both the LT and the FX, and the Stomp come to think of it. And most of my activity is with the Simplifier II and Tech 21 Fly Rig at the moment. Am thinking of putting the Simplifier together with the FX and relying on the Fly Rig for open mics for boring "this thing has a lot of knobs to be knocked out of position" reasons re: the Simplifier.
When I decide on a solution I don't really get option paralysis, but boy do I get it when I'm trying to decide on which solution to go for.)
