Building /assembling a guitar around the pickups! DeArmond content
OilCityPickupsOilCityPickups Frets: 10689
You can see here how I'm bringing a pair of early fifties DeArmond 2000 Dynasonics back to life after serious water damage.
This is where I'm going to hopefully put them into a Tele body and create a Dynasonic equipped 'Cabronita' with hopefully a Bigsby style trem.
The pickups have been waiting about five years for me to find the time and inclination to do something with them ...
I initially thought of some cheaper Gretsch solid as a host ... but having had a couple of  Electromatic Jets in the workshop I wasn't impressed. Heavier than my Gibson Les Paul and still with a neck profile I'm not keen on.
The trouble is, the surface mounting Dynasonics need a load of clearance, and most solid guitars don't have the strings high enough off the body ... or indeed enough body depth to be routed away to take the 'valve gear' hanging out the back of a Dynasonic.
Then I remembered an unfinished Cabronita style body I had packed away in the workshop. I had started putting an aged red stained Tru-oil finish on it ... but on trying it with a neck ... the neck sat really high ... ah ... actually exactly what I need now!
So I went ahead and ordered a new roasted maple tele neck ... but as yet none of the design elements are set in stone.
I will need a high bridge to allow the strings to clear the pickups ... I have a Rickenbacker style one but it's fairly horrible ... besides I'd prefer rollers to use with a flat mount horseshoe style 'Bigsby' ... I shall probably pick up a cheap 'Chibsby' till I know if this concept will fly ... watch this space
If you have any parts suggestions please feel free ... the body and neck are all I have as yet.
«134
  • Winny_PoohWinny_Pooh Frets: 7802
    Need to see pics. A tune-o-matic could do fine
  • OilCityPickupsOilCityPickups Frets: 10689
    Pics of the bits so far on Monday ... and I was thinking of a roller style tune-o-matic (Northern Guitars I think) ... had one fitted on my old Ibanez semi acoustic with a Bigsby ... held tune very well.
    Neck will be here late next week.
  • SporkySporky Frets: 28715
    Could you do one of those Duesenberg Les Trems? A bit less bulky than a Bigsby.
    Hummm lets find a piccy
    The only Issue here is I'd still have to drill in a pair of tailpiece stopbar posts ... as well as bridge posts. The other issue is cost.
    I want to put this guitar together with as many recycled and low end bits as I can in order to see if the resulting guitar is worth  improving. A bigsby knockoff could easily be replaced with a Bigsby if I find I have a guitar I like here.
  • lovestrat74lovestrat74 Frets: 2533
    Interested to see how this is going to work. I passed on some repros because I didn't think they would be too tall to work with a Tele body.
    I already had the vernier calipers out ... it'll be tight, but on a full 45mm Tele Cabronita body with that shallow neck joint they should fit (given that I'll shim a slight neck angle too).
    I will have to rout the bejesus out of the pickup holes ... leaving less than 1/4 inch of body ... but that's fine.
    I may also have to source some long neck bolts due to the thickness of the body 'tongue'.
    Looking forward to this :+1:
    In fact a better idea may be threaded inserts in the neck heel ... then long bolts are easy
    What about building up the neck pocket to be taller with a fat full length shim?
    I've often though about doing this, then taking a B5, cut off the roller and recess whats left.
    Eg
    Eg
    Shouldn't have to the neck pocket is way shallow in the Cabronita ... probably because of the height of Filtertrons :-)
  • FunkfingersFunkfingers Frets: 14575
    The obvious comparator model would be the Fender Tele-Sonic. (Set neck, 24¾" scale length, wrap-around bridge.) I can not pretend to recall the neck pitch angle.
    If the partscaster is going to have a regular Stratocaster-type hardtail bridge, it may be necessary to engineer the neck pitch angle into the neck pocket floor à la Eighties Charvel Model series.
    edited February 24 tFB Trader
    No it'll probably have one of these
    with a Bigsby behind it
    The fender design wouldn't work with vintage Dynasonics
    These pickups in this have got super short magnets and are height adjustable ...
    Not like vintage Dynasonics at all. Mine are from around 1953  :-)
    The colour is actually very close to the finish I already have on the Cabronita body
    Scale will be Fender 25 1/2 and probably with one volume and a pan pot.
    The pickups in [the Tele-Sonic]  have got super short magnets
    Like the TV Jones T-Armond.  :)
    Mine are like the full fat vintage ones on the right ...HUGE magnet mass ... hence the mahoosive tone of the early ones.
    So the body is going to be somewhat lighter once all that wood is out :-)
  • WezVWezV Frets: 16791
    Exactly how deep are they?   Any room for recessing the pickup by a few mm
    I'm not at the workshop so cant measure ... but really deep ... I worked out that with them surface mounted I'd have about 4mm of guitar back left!
    Of course they were meant for semi acoustics ...
    The middle example looks like a TVJ bridge position unit.
  • MikePMikeP Frets: 59
    What do you die/ tint your tru oil with?
    I rub the die into the wood before oiling :-)
