Learn how to use Snapshots. They are as they sound - a Snapshot of settings.
So while you can have 1 f/s changing up to 8 different things in a simple state (on/off etc) with Snapshots you can recall all manner of things.
So you set a sound. Then for sound 2 you'd like a Tubescreamer on, but some more mids on the amp and an increase in output. So Snapshot 2 does that.
Snapshot 3 can then leave the TS on but turn up the tone on it a little while at the same time boosting the gain and bass on the amp and activating a delay.
Snap 4 can then add a phaser, then change the delay time from 600ms to 300ms and increase the feedback while also boosting the presence on the amp.
you can do all this sort of stuff in 1 patch so there's no patch switching delay. It's brilliant.
DM me your email and tomorrow I'll send you a couple of patches with Snapshots on so you can see what I mean.
A better solution might be to assign the drive parameter of your amp to a footswitch and/or a snapshot, essentially switching between two settings of the same amp. Some of the latest Line 6 'original' amps also have a boost feature that's voiced to the amp itself; this can further add gain.
