I sit on the friedman BE and a klon for 90% of my playing.
The more I look into this the more I think I want one. I only really play at home now anyway but I think with a 2 button FS it would be giggable too, could make a nice compact board with minimal option paralysis. Interested to see some demos from the usual suspects, would be cool to hear some heavier tones with the Placater through a V30 cab
Yep. The "crunch" amp model is the Friedman BE/HBE too.
Thinking I could have a nice little board for playing at home (or even gigs) with this, a tuner and a Digitech Drop. I'm not much of an FX user so the built in ones sound good enough to me, and the flexibility to assign them to footswitches is a great feature, even just for jamming along to tracks at home.
https://www.youtube.com/watch?v=ssYtRNzSwxY
I like HX stomp but it needs a supply of 9v @ 1 amp if you’re using a rechargeable power bank
And the pod go uses more . I’m becoming less sceptical than I was when I first saw it .
JNC has done some good demos
I think that the Pod Go is an excellent unit, with a simple and brilliant interface.
Core sounds are way better than the price too.
However, mine is being returned, as it does produce a wee bit too much noise in my set-ups.
YMMV.
