Recommend me a neck relief measure tool
liamonliamon Frets: 105
Doing a bit of tinkering and could maybe use something more scientific than eyeballing. Anyone have a recommendation for a good tool for neck relief measuring? Cheap is good.
  • pt22pt22 Frets: 318
    Capo on the 1st fret, finger on the 12-15th. This will rely on level frets. Otherwise a notched straightedge which you can find on Amazon or Ali Express pretty cheap.
  • ElectricXIIElectricXII Frets: 1196
    A cheap capo at the first fret and a set of feeler gauges is all you need.
  • Hydra19Hydra19 Frets: 329
    edited April 21
    Cheap feeler gauges, I've had mine for a while and am worried they are not totally flat anymore.....anyway, Dan Erlewine recommends using a popsicle stick and gluing on a .010 gauge string, that becomes a DIY 0.010 feel gauge, which can be better than eyesight (obviously just a little part of string that's been cut)
  • daveyhdaveyh Frets: 687
    100% this
  • TanninTannin Frets: 5623
    Go to any car parts shop and get a set of metric feeler gauges. (Metric because it is much, much easier and less error prone for small distances.) Something like these: https://sydneytools.com.au/product/toledo-301159-feeler-gauge-tapered-10-blade-metric
  • ICBMICBM Frets: 73003
    Cut the end off the new top E string, and use that as a feeler gauge. That’s the perfect relief in almost every case, regardless of gauge.
  • liamonliamon Frets: 105
    edited April 21
    Yes sorry it’s the feeler gauges I’m looking for. Didn’t know what they were called. Thanks, have ordered some!
    That is surprisingly low!
    It can often be even lower than that if the neck and fretting are really perfect. You don’t want it quite dead straight, but the closest to that which is possible without rattling in the low positions gives the best feel up and down the neck. The bridge may need to be raised slightly if it then chokes around the 12th fret area.
    Most guitars don’t play as well as they can because they have too much relief and the bridge is then set too low to try to give a nice action.
  • SteveRobinsonSteveRobinson Frets: 7113
    In all my time I've never measured relief. I start with the neck straight then add whatever relief is necessary, normally very little.
  • jasonbone75jasonbone75 Frets: 677
    Agree 100% with both. I don't know anyone that has ever measured it either. I don't agree much with player's statements along the lines of "set it to my preferred relief" or "the relief I like". You set it to what the guitar requires and play it.
    If a player needs more relief than the guitar requires they should probably work on their technique some more :)
  • FelineGuitarsFelineGuitars Frets: 11729
    Imperial feeler gauges with 25 or so blades, and a capo for the first fret
    Work for anywhere between 0.004" - 0.014" for relief....adjust to taste
  • FunkfingersFunkfingers Frets: 14728
    Breed gnats.
  • euaneuan Frets: 1620
    Aren’t they not particularly straight?
    Metric is only easier if you don’t know how to use imperial, otherwise it’s six of one half a dozen of another. If you are doing anything with comparison to USA standards imperial is the better option.
  • BillDLBillDL Frets: 7695
    I don't measure relief other than sometimes for curiosity or to keep a note of it it's somebody else's guitar, however string offcuts make excellent guagues:
  • digitalkettledigitalkettle Frets: 3354
    Am I doing it wrong?
     - guitar tuned up and in playing position
     - left hand depresses G string at first fret
     - right hand little finger holds down G string somewhere near the body join
     - right hand first finger taps G string near the 7th/8th fret while sighting the gap (a well positioned phone screen below can help visibility)
  • OilCityPickupsOilCityPickups Frets: 11065
    Same here.
    That’s exactly how I do it.
  • fretfinderfretfinder Frets: 5106
    edited April 21
    Me too except I do it on the top and bottom E strings, don’t know why I just always have.
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
