Metal RCA 6V6's in a 5E3
springheadspringhead Frets: 1602
Friend of mine gave me a NOS pair of them.  They measure about the same as the new Tung Sol 6V6's I had in previously.  Idling at about 12W.  They sound very good, maybe a bit more attack on notes.  They smell different!  Hot metal I guess, and maybe a bit of 60+ year old paint burning in.
Anyone else tried them?
  • ryanverbenaryanverbena Frets: 436
    I always thought this was a huge no-no?
    No real justification, just remember being strongly advised against it once.
  • ICBMICBM Frets: 72663
    Probably just about OK in a 5E3 Deluxe - the HT and screen voltages are quite low, although still above the valve ratings. Definitely a bad idea in a Princeton Reverb or Deluxe Reverb, or even a BF/SF Champ, they will probably fail immediately.
  • springheadspringhead Frets: 1602
    From data sheets I found the spec was the same. I always had it in my head that the metal versions were lower rated though. The anodes are sitting at about 360V with around 18V on the cathodes. So 340 ish across the valve.  Have you seen data sheets that suggests that’s pushing them?
    I run that amp with power scaling which works very well in a 5E3 so most of the time they’ll just be ticking over.
    The datasheets do suggest that, but more importantly the practical experience of a large number of builders and techs is that the metal ones don't survive at Deluxe Reverb-type voltages but 6V6GTAs do.
    What does a deluxe reverb run them at , 400+ ?they do sound rather good and as with my power scaling they’ll be probably under 200 most of the time apart from any outdoor festivals hopefully all is well.
    Yes, typically around 420V.
  • RiftAmpsRiftAmps Frets: 3180
    The metal screen is connected to pin1 which is usually the parking point for the grid-stopper on modern 5E3 builds. I would just confirm socket wiring before continuing.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    Good catch. I built the amp but can’t remember if I used pin 1. I’ll open up and check. Thanks!
