I did go down a rabbit hole on the modifications made to the Plexi by Martin Golub. Info's a bit thin on the ground and he died a few years ago so there probably won't be too much more.
I did unearth a couple of internal shots of one of his Dookie-modded amps. It does look to be some sort of cascaded gain stage conversion, similar to the Appetite SIR #39/36 amps and the Jose Arredondo stuff. It looks like it was converted to a 2203 JMP Master/800 circuit, and then a gain stage was added somewhere down the line which would account for the fourth preamp valve poking out the top. It has a master volume too.
Very cool!
I have a mini 800 which sounds reat and is loud enough to gig with, bearing in mind that there is a 99.999999% chance my drummer is louder than yours.
Yes Martin used to work at LA Sound Design, and I heard about his passing sadly. I wonder if he did hand down any tips to any amp techs.
I have a Dookie Mod Kemper profile and they're ok, and its close, but nothing beats that sizzle of a real cranked tube amp (or two) through a 4x12. I had to tweak the speaker cabinet on the profile as it was far too bassey and dark.
https://i.imgur.com/hW7ELNF.jpeg
https://youtu.be/YZveZOnuHNo?si=feOiIXbyfNgWreRr
It ain’t flashy, but it does the job.
This is also why it’s best to raise the guitar amps off the floor, but keep the bass amp down on it - that naturally rolls off some of the bottom-end from the guitars but reinforces it on the bass. If the band mixes itself correctly ‘acoustically’ it’s much easier to get a good mix through the PA as well.
