I find it's the acid etching followed by heteroepitaxy which results in the lovely golden colour and crispy edges that we all crave.
JM build | Pedalboard plans
Offset "(Emp) - a little heavy on the hyperbole."
soundcloud.com/thecolourbox-1
Source: Joshua Weissman YouTube channel
Brined Fries
Serves 2 people
2 large russet potatoes
35g kosher salt
750g water
1 clove garlic, lightly crushed
¼ teaspoon (1g) brown mustard seed
½ teaspoon (2g) black peppercorn
Peel the potatoes and cut them into ¼ inch planks. Cut the planks vertically into ¼ inch sticks. Optionally, rinse the cut potatoes in cold water, then pat fries using paper towels until as dry as possible.
In a quart sized mason jar, add water and salt. Whisk until the salt is fully dissolved. Add garlic, mustard seed, and peppercorn, followed by the cut potatoes, ensuring they’re fully submerged in the brine. Place a lid onto the jar, making sure air can escape, and let sit at room temperature for 3-5 days. If for some reason this causes the jar to overflow you may need to switch to a larger container and add additional brine to cover. To do that simply make a second batch of brine and continue adding until the potato is submerged.
Fill a 6 quart Dutch oven or heavy bottomed pot with vegetable oil and heat to 320°F (160°C). While the oil is heating, drain the potatoes from the brine and pat dry using a paper towel.
Fry the potatoes for 1-2 minutes, or until the fries turn pale in color and matte on the exterior. Transfer to a paper towel lined baking tray and pat dry of excess oil. Bring oil to 350°F (176°C) over medium high heat.
Fry potatoes once more for 2-3 minutes, or until the fries are a deep golden color and crispy. Using a spider, remove the fries and allow a moment to drain off excess oil before adding to a large mixing bowl and immediately seasoning to taste with salt. Toss while seasoning to get an even coating. Serve hot with dipping sauces of choice.
Too many issues with cutting your own and deep frying. Potato type, starch content, oil, whether they are soaked first, need drying etc etc.
On rare occasion i do, par boil, drain, fridge to dry and cool, then fry..
Or, cold oil chips are great /easiest from raw, washed first, dried with tea towel. Into a pan of cold oil, on with the heat. Cook until they float.
Parboil them.
Then 3 or 4 mins at 140C, take out and let cool.
Then 3 or 4 mins at max temperature.
Also, use beef dripping for frying in.
