Offset "(Emp) - a little heavy on the hyperbole."
But if you want to understand it better.... what’s happening here is it’s reading the red section as your data name, and a20:b20 and c20 as data.
The biggest issue is that Excel can't show times on an axis when it sees col A as Date-Time, it needs to know you want it represented as Time alone. I suspect this is because showing minute-wise data across multiple days isn't good practice for large data sets like this.
Doing what you've detailed above; Select Data, edit Horizontal Axis Labels to the A column data, then clicking on 'Remove' in the left box deletes everything - including the edited right box contents.
Put the number 1 into a spare cell
Copy it
Then do Paste Special>Multiply
Success!!
Thank you Drofluf!
How the hell did you find that out?
I expect importing that into the latest Excel was a less than perfect operation.
Strange - I tried setting the cell formats to number and that didn't help but doing what you did fixed it.
CSV was always the path of least resistance!!
