I'm looking for suggestions for an EQ pedal. I'm currently using a Pearl 9-band graphic (directly after overdrive/distortion). I quite like the GEQ way of setting up the sound, but don't mind something more akin to a typical 3-band amp EQ with presence.
My current amp setup is a stereo valve hi-fi amp into two 1x12 V30 cabs. With no EQ, it sounds pretty middly, and quite different from my Laney Cub 10 - with the latter, I hardly ever used the GEQ, but it's on all the time with the stereo setup. The stereo amp setup might change eventually to an amp, or preamp, that has typical amp EQ included. Or it might not, especially if there are options out there that would allow me to have at least two sets of EQ settings (eg, heavily scooped, and not so scooped).
Is there anything out there that's programmable, or at least offers switching between two distinct sounds (not including 'off')?
Alternatively, is it feasible to build a single ECC83 3-band tone control box, with presence, that has (near-)silent switching between two tone stacks?
Nomad
the other guitarist in my band has one of them. Looks pretty.
I kinda want it, but I really want a noise box more.
