Polarity Puzzles!
robwrightrobwright Frets: 739
So I understand about polarity (Boss = centre negative, EHX = centre positive on a mini jack). But ...... If I use a converter from barrel socket(?) to mini jack which has no label, can I assume that it is wired to centre positive (as it is a Jack) therefore reversing polarity - or is that a dumbass assumption???? I have a number of EHX pedals but no matching adapters and too scared to plug them in!! If it isn't that simple, how can you test what the pins are? Is this as simple as putting a meter on it? If so, what meter???? Ta xx
