I have the fuzz stacked in loop 5. Tuner has its own port that's not in the loop but always on. You can see my sticker next to the switch.
I still need to get some midi cables (Best-tronics), and then the DPC5 can control the Timeline and BigSky with Midi even though they are out of the loop.
There is a USB port at the back, I believe Disaster Area were doing work with Joel at Chase Bliss which can use the Warped Vinyl and control via the DPC 5 too somehow, I have not updated the DPC5 yet and you need a Midi to TRL cable for that, will do that at some point.
@cbellanga here has one. He should be able to tell you where he sourced his from.
The musicom efx 6 lite has 6 wired loops and can control 2 midi devices.
It also has 2 cc functions and can switch between manual and preset modes.
Both amazing devices, it really depends on how many things you want to connect to it.
I bought the lite one from loopersparadise for £235 + delivery if I'm not wrong but selling here for £200 delivered. The mkiii I got used.
Hope it helps but can give you more specific info, just pm me, happy to help
