18v pedal powered with a Harley Benton Junior?
markblackmarkblack Frets: 1591
Is it possible to use two 9v outputs with the y cable to power an 18v pedal? Or am I being dumb.
Cheers.
  • hobbiohobbio Frets: 3440
    I thought that was why they supplied it?
    electric proddy probe machine
    My trading feedback thread
  • Yes but you'll have to buy a y-cable or make your own. The yellow y-cable they supply is a 'parallel' cable for current doubling (still 9v). You will need a 'series' cable for voltage doubling (18v but the same current as a single output).
    I can confirm that this will work ok as I do exactly this with my Award-Session JD10 and my HB PPJnr.
  • markblackmarkblack Frets: 1591
    @steamabacus  many thanks. M
  • What about a Diago 18v adapter?
    (I think I've still got one somewhere, I certainly used to have one and I don't recall selling it)
    Yeah, thanks for putting me straight mate. The supplied y cable is for 9v pedals that require more than the 120mA per output it supplies then?
    If I remember my physics correctly, I suspect that adapter will also result in a current drop, maybe even halving the current? The HB PP Jnr only has 120mA per output so that may possibly be a problem.
    Specs list it as being able to supply 30mA, so ideal for drive pedals but not much else.
    I used to use it with a Catalinbread DLS Mk3 because PGS Andy told me it would sound better ;-)
  • crunchmancrunchman Frets: 11464
    The Diago one is fine for drive pedals.  Will leave you an extra output spare as well.  I think I've got one or two of them lying around somewhere.
  • EdGripEdGrip Frets: 736
    The one they supply is a current-doubler, to let you use a 9v pedal (or daisychain) up to 240mA current.
    You can buy a voltage-doubling Y-cable, which is different, to let you use an 18v pedal (or daisychain) up to 120mA current. Various companies make these; I think mine is T-Rex. I bought it from Thomann at the same time as the Powerstation Junior. They're about £6, but you just have to take the hit (or make your own).
    For clarity the Diago that I (and @steamabacus) have been talking about is not a Y cable.  It has some kind of charge pump arrangement that doubles the voltage so you can do 18V off a single output.
  • Dave_McDave_Mc Frets: 2362
    Yeah. I recently got an 18V pedal, and luckily I thought, "I'd better check the manual, just in case." As you said, according to the manual it's a current doubler, not a voltage doubler.
    I never got round to buying a voltage doubler cabler. :))
