For structure I use timeboxing, which basically means applying a hard time limit to each activity. I find it immensely motivating - it really takes the willpower element out of practise as well as providing a clear structure.
I use this web app for it at the moment: http://timeboxer.ericjorgensen.com/ but there are plenty options as apps, or just use a written list and an egg timer.
As for scales - start with the major scale: everything else is defined in relation to it so knowing it is like learning to read a map before going exploring. This will also help with learning the notes of the fretboard, and learning intervals (practising the major scale in ascending intervals is extremely musical).
Within each half. Arpeggios & scales 3 mins max at each, chord changes perhaps less. Sections of new tunes that are tricky.
At the end: reward yourself with a wig-out and play some stuff just because it's fun.
Speeding things up: always play it slowly so you can execute it cleanly before attempting speed. You are programming your motor system so do not program in mistakes! When you can do it right with your eyes shut, find the fastest speed you can do it without making a total mess. Then drop back by a few bpm to a speed which is faster than your previous habit but still allows clean execution. Tomorrow, push the boundary a bpm or two further, then drop back to slightly faster than yesterday.
Always use a metronome even for scales & arpeggios. Always listen to your sound. If it isn't that good, consider how your pick approaches the strings, how you fret the strings, or your control pot settings. Aim for the most pleasing & musical sound.
Plus what @mixolyd said
EDITED for typos
just an idea, probably far to complicated to organise, but..
are there any guitar teachers or would be teachers ( who would like to test out their methods ) on the forum who would be prepared to set some sort of technique challenge on a ( time permitting ) reasonably regular basis , where players could submit videos/audio of their attempts for the tutor to critique?
Or it could be just someone showing how to play a particular passage or lick
There could be variations in difficulty/style etc.,
It could be good practice for the tutor in getting ideas across and a great resource for tight bastards like me who don't want to pay for lessons
The Complete Guitarist & Guitar Handbook are good references for both beginner & advanced players, I still use mine for scale/chord references, check your local library if they have a copy.
+1 for those. I have both. The latter is IMO more suited to beginners in terms of the way it explains stuff that beginners need to know (the former is not quite so beginner-friendly) and the latter contains advance stuff that the former doesn't. Both books are well done though. If I have a beef about the latter it tries to compare the structures of various scales all beginning on C, but doesn't make it totally clear that all those different scales are not necessarily in the key of C or derived from it. for example, C mixolydian is the 5th mode of F major and IMO belongs in a discussion of the key of F.
My current routine (bear in mind I'm just trying to get back into a routine) is
15 mins finger exercises speed not a worry, but to a metronome.
15 mins scales, again speed not a worry, but to a metronome.
30-45 minutes of refreshing songs I've previously learnt/partially learnt.
Some time in the next couple of weeks the refreshing songs will be reduced to learning new stuff/working through some techniques books.
I have one book which more or less is teaching blues licks, another teaching major scale/chord tone soloing, and another dealing with blues rhythm playing (with which I'm using a looper, and then soloing over the top). Then I do transcribing, using a Boss BR80 to slow down parts when I need to.
What I've noticed is that there's definitely a sweet spot where you're making the most progress, then a point where progress becomes so slow that you're MUCH better off moving on to something else. It probably takes me 2-3 minutes to get into whatever I'm doing, then the next 25-30 mins is where the quickest progress seems to happen. After that I move on to something else, and that seems to 'reset the clock' if you like.
The sweet spot I would guess changes depending on what you're practicing. You wouldn't spend 30 mins practicing a chord change, but you might spend at least that learning a song for example.
