If you use a lot of gain it can be very difficult to get the delay mix right, tends to muddy the sound unless you only use a tiny bit, and you can't then use the same delay setting on a clean sound or you won't hear the delay at all. Putting the delay in the loop fixes all that.
An OD or Distortion, even full up won't damage the amp into the front end.
Put in the loop they can get the amp to fry itself* internally.
Delay sounds good in the loop, especially, as has been said, if you're using clean and dirty channels and a lot of gain.
clean/slightly crunchy the delay can sound good in front.
As for using 4 cables, I put the pedals in the loop to the left of the board, and those into the front to the right.
*technical term.
Eventually I will buy an isolated power supply!
I think I'll just pick up a couple of decent cables that are a sensible length with one right angles end.
That way they will sit on the pedalboard just like patch cables
Can always sell my diago on for a few quid at least
Any recommendations for a psu?
I was looking at the t-Rex fuel tank a while ago.
