By the way:
Young does, however, use a range of pedals and devices to create effects sounds in and of themselves. He relies heavily on a particular vintage Fender tube reverb unit, which is set up with a separate spring pan mounted to the top of a microphone stand that is anchored on the cement floor below the stage he is playing on (often with a hole drilled through the floor to bring springs and tube-reverb chassis close enough together!). The convoluted arrangement is undertaken in order to avoid the disruptive, wet “sproing” sound that ensues when you stomp on a stage with a lively spring reverb unit sitting on it. Young also makes use of an analog delay, an octave divider, a flanger, and a digital delay.
electric proddy probe machine
My trading feedback thread
